Any at home tricks for subframes?
88GT17MA
289
Going to be installing subframe connectors. I assume I would want to do this with the load on the suspension/body/frame so that they are seated properly. My cars pretty low, couldnt imagine welding under there with that little space, and I dont have a lift....any suggestions? or am I off to the shop on this one?
Put jackstands under the rear axle housing and under the k member. I've done this on 5 T-Birds my 2 mustangs 3 friends mustangs and a 63 comet and all turned out very well. Since youre already under there I would take off the controll arms and reinforce the torque boxes by welding the seams. You may consider also installing a driveshaft loop at the same time. I weld mine in and weld it to both subframe connectors, making a giant h brace out of the subframe connectors and the loop.
Buy/use 2 pairs of ramps ...
If you can get a jack under the thing, jack it up until you can slide the ramps under the tires. For other repair jobs I've used steardy concrete blocks to set the tires on as well.
Definitely weld around the perimeter of the ca torque boxes while you're under there :nice:
