Any benefits from FRONT Eibach Drag springs ?
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
I have a friend who sells 2 brand new FRONT Eibach Drag springs. Usually, when you buy the kit, it comes with 4 springs. So now, I'd only be running the front Eibach drag springs.
Would I see some gain or do I REALLY need the full kit with the rear springs to notice something ?
The guy is selling the set for 75$. He says that 1/2coil has been cut on each.
BTW, I already have Lakewood 70/30 struts in front, subframes connectors, upper and lower control arms, if that can help the advice.
Thanks
It is best to go with a whole kit because the Eibach also has an air bag in the passenger rear in attempt to get these car to leave straight. I only say attempt because my car still pulls the left front up more than the right and I run 20psi in my air bag. With your current mods and such with the complete Eibach kit I see no problem with gettin mid to low 1.6 60's on motor and 1.5' on the N2O considering you are running ET Drags.
