any door handle and mirror removal tut
robertdeuce
147
i trying to remove my door handles and mirrors to do some body work but i dont know how. i have the door panel off but cant get at the door handle bolts from inside, the window is in the way.
anybody have any ideas or a link to a tutorial?
window shouldnt be in the way if it is rolled up. If it is an original door handle then they are correct above the rivets need to be drilled out. When you pulled the door panel off you should have pulled off the mirror cover on the inside which hides the bolts for the mirror.
