Any ISC test out there?
brytell
35
Rio Rancho, NM
Hi my car is idling around 2000rpm and when i pull the ISC plug the idle drops to around 850rpm. The idle then goes up and down between 850-1200rpm. I have a 93 cobra cam in its so im thinking the ISC is stuck open and not closing. Is there any thing I could do to test the ISC?
Thanks.
Brytell
Not really a test, but a reset.
Unplug the IAC and set the idle using the screw under the TB. Set it low, around 600-700RPM or right above the point where it will stall. Then, shut the car off, and unplug the battery.
Take the IAC off and clean the hell out of it with brake parts cleaner or carb cleaner. Make sure the plunger inside can move freely. Put it back on the car and plug it in. Hook up the battery after 30 mins and start the car and let it relearn idle again. It should settle out around 850-900 or so.
How come you are running a '93 Cobra cam? It's the same cam as the 91-93 cam and is really a terrible cam. If you want a nice factory cam, the 85-88 cam is the most aggressive.
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems.
I continue to update it as more people post fixes or ask questions.
