Any Opinions On The Typhoon Intake?
Yea RC, str8stang and I have it.. Not sure if anyone else in this forum does.
Its a copy of the Edelbrock RPM intake. The casting is horrible, but once polished will look quite nice... I would make sure you have a combo that needs the typhoon..
My only issues with it was... I had to notch the lower intake cause the fuel rail was hitting it. Also, my thermostat housing doesnt line up right, so it drip leaks. I tried to fix it a number of times with no luck.. Ill get to try again in a month or so when my cars runnin again.
Other then those issues its a good buy. Personally if i did it again i would look for a used RPM intake. You can find them for around 350.
