Any Reason I Can't Use A Little Sealer On Water Pump Gaskets?
oz
1,079
10
58
Plymouth, MI
My water pump gasket has leaked a little - mostly in the winter - since I installed it 10 years ago. I've got the thing torn down for other reasons (another thread) so I'm going to install fresh gaskets.
I got the pump off and the plate that seals that back side is a little pitted (and may not be perfectly flat) so I wonder if there's any reason why I can't use a little RTV silicone on the metal surfaces and then sandwhich the gasket? I installed the gaskets dry last time so I want to do something different this time...
THANKS!
Thanks.
In general I think it's a pretty crappy design - having that little plate held in place with two bolts at the bottom and thinking that a gasket and those two bolts will hold the water in. I usually use RTV on gaskets but didn't this time.
I have one of the heads off - should I put something around the water passage hole when I put the head gasket on?
Had the best results with Hi tack gasket cement on these. Next up is old fashioned Permatex No 2, it seals well, but is a pita to remove. Have used rtv w/o gaskets, but went back to gaskets. The rtv always made the gaskets slippery when I tried both at once.
