any suggestions?
  • Thread starter Thread starter 87WhiteStang1
  • Start date Start date Sep 23, 2009
87WhiteStang1
182
  • Sep 23, 2009
so i am still dealing with a horrible missfire like a ihave been for the past couple of weeks and i can't figure it out. it spits and sputter under load and when cruising it cuts out slightly. at WOT it feels very underpowered and will sputter alot. iidle will sometimes sit right around 700 and the needle will shake alot. then sometime the idle will go back and forth from about 700 to 1500 and sometimes even around 2 grand. all ctlinders get spark from what ive seen. fuel pressure sits at 32psi at idle and goes up to about 38-40 when on throttle. fuel pressure at about 44psi when vacuum line unhooked. i'm not sure whether this is fuel or spark related but heres what ive done so far:
-fuel pump replaced with walbro 255lph
-dist replaced not long ago, tested it today with dist out of another car.
-timing set at about 12 where it has seemed to run good in the past.
-msd blaster ign. coil
-plugs ,wires, cap & rotor replaced/plugs gapped
-new fuel pres. regulator
-checked for vecuum leaks in engine area
-egr tested
-headers tight
-o2 sensors replaced
........any other suggestions please! i want to get this fixed but i may just bring it to a shop because i have been dealing with it for too long, thanks
2000xp8
SN Certified Technician
Aug 8, 2003
8,073
1,656
194
NJ
Sep 23, 2009
  • Sep 23, 2009
Did you try swapping out the msd coil for a stock one? They are notorious for being poor quality.
87WhiteStang1
182
  • Sep 23, 2009
yes i have a brand new stock replacement that i swapped out. i guess i should have said that.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 23, 2009
  • Sep 23, 2009
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
