Anybody have the part numbers for SN95 spindles??
everything i've read says, check the numbers on the reverse side of the spindle and you'll see a ford part number.if you see either F4Z8 or F5Z8 then you have 94-95 spindles. The first two digits are the year code. F4= 94 F5 = 95.
or another method is..
checking the spindles is even easier than that.
look at the tie-rod mounting arm on the spindles.
if it's straight or is it curved
curved arms are the 94/95 spindles
straight arms are the 96+ spindles
edit:
someone else actualy posted this, i just did a copy and paste.
All you need are the first two numbers
F4 refers to 1994 engineering number
F5 = 1995
F6 = 1996+
F7....and on and on. Around 1999 or 2000 they changed this
1994 and 1995 came come with both F4 and F5 part numbers. I don't know what the difference is but i have one of each on my car (came form two different cars) visually there was no difference.
