Anybody used this rear disc kit?
NicD
57
Brand: Stainless Steel Brakes Corp. (SSBC)
Rear Rotor Included: Yes
Rear Rotor Diameter (in): 10.25 in.
Rear Rotor Diameter (mm): 260.4mm
Rear Rotor Thickness: 0.949 in.
Rear Rotor Construction: Vented
Rear Rotor Style: Solid surface
Rear Caliper Included: Yes
Rear Caliper Type: Cast iron
Rear Caliper Piston Quantity: Single
Parking Brake Provision: Yes
Parking Brake Style: Integral caliper
Rear Caliper Finish: Natural
Rear Caliper Material: Iron
DOT-Approved: Yes
Quantity: Sold as a kit.
Notes: 4-lug x 4.25 in. bolt circle. Master cylinder included.
Disc Brakes, Rear, Solid Rotors, 1-Piston Calipers, Ford, Mustang, 8.8 in., Kit
$739.95
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SSB-A112-1&N=700+115&autoview=sku
Opinions?
I have it on my car now its easy to install but me and my dad forgot to bench
bled the Master cylinder and my pettle is mushy but im use to it.It will still lock up the back brakes if I try to make all 4 lock it will at about 80% down.Only thing bad about it was the it came with a 87-92 e-brake cable and its to short but other then that good kit.
Thanks for the reply...
How long did it take you to get the kit it? Was it fairly stright foward?
