anybody wire an illuminated switch to replace the spout connector
Dan95-5.0
1,110
Manitoba, Canada
i've been hiding all my wires in my engine bay and i want to add an illuminated switch to replace the spout connector. i dont want to have to get into the fender everytime i want to change my timing.
has anybody done this?
the switch i got has 3 terminals. power, acc, and ground.
i'm no electrical genious. can i make this work?
thanks for reading
I dont know that I'd use a lighted switch, but using the switch (without the lighted element) certainly works fine.
Good luck.
If you use the switch you are going to need to run another 2 wires. One ground and one power.... Unless the wire is already grounded at one end then just run a however many volt wire to the LED. I Would just use a regular switch with one side labeled on and the other off.... Makes it so much easier.
i wouldn't mess with an iluminated switch. i tried putting one in for my manual fan. yeah i got it to work, but it does the opposite; lights when its off, doesn't when its on.
I used an aircraft switch for the fan. No light to wire up, and it's pretty east to tell when it's on as the aircraft cover is up. :nice:
Everyyone thinks it's my NAWS switch, but I tell them it's my turbo. Flip it on and they can hear the fan kick on high. :rlaugh:
thanks for the help guys.
heres a pic of the switch i wanted to use. looks sweet there.
i might just use it without the led to turn on and then figure out a way later.
