Anyone do the hydrolic clutch upgrade on their car? I am really leaning towards doing this. The kit is just under $600 from CJ or LMR. Does not look to hard to do. This may be the final cure of this clutch issue that I have been having.
Problems being the constant going out of the release bearing, which now I find out may be that the retainer has been bad?
Other being the stiff pedal.
My delima is, they make 2 diff types. One that has the external slave that simply goes in place of the cable, fork, bearing and all stay. Well even thought this style is an easier install, no trans removal. I would have to pay more to still replace the fork, bearing , and retainer shaft.
The other style is an internal slave which basically is the release bearing. The fork and old bearing is removed for good. The lines simply come through the opening of the trans where the fork does. A little more difficult to install because trans has to come out.
So what would you do, or again has some one done this yet?
