S Stang813 New Member Dec 3, 2018 28 0 1 Tampa Dec 9, 2018 #1 Dec 9, 2018 #1 Does anyone have a ecu that is broken with good capacitors? Mine needs fixed. Attachments image.webp 173.2 KB · Views: 219
S sd331 Member Sep 9, 2008 69 19 18 NJ Dec 9, 2018 #2 Dec 9, 2018 #2 go on ebay..look up seller 'pontisteve'.. he sells a rebuild kit that has all 3 caps for the eec.. Reactions: Stang813
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,349 18,084 224 Massachusetts Dec 9, 2018 #3 Dec 9, 2018 #3 Those caps can be had cheaply from Mouser.com. Just need to know the specs Reactions: Stang813
S Stang813 New Member Dec 3, 2018 28 0 1 Tampa Dec 12, 2018 #4 Dec 12, 2018 #4 Thank you . I ordered it from amazon. Getting here today. But if not I need a ecu as a backup
Blown88GT Founding Member Nov 13, 1999 2,283 524 164 Palm Beach Gardens, FL Dec 12, 2018 #5 Dec 12, 2018 #5 Your picture doesn't show any electrolytic capacitors. You already removed them?
S Stang813 New Member Dec 3, 2018 28 0 1 Tampa Dec 12, 2018 #6 Dec 12, 2018 #6 No I just replaced them . Do you or anyone have a ohm reading of how much it should be? Attachments image.webp 282 KB · Views: 214
Blown88GT Founding Member Nov 13, 1999 2,283 524 164 Palm Beach Gardens, FL Dec 13, 2018 #7 Dec 13, 2018 #7 Ohm reading for what? Capacitors are measured in micro-Farads (uF). They should be mounted close to the circuit board. You've got them way up in the air. Don't want them moving around or breaking off a lead. Reactions: Noobz347
S Stang813 New Member Dec 3, 2018 28 0 1 Tampa Dec 13, 2018 #8 Dec 13, 2018 #8 Thanks man. Yeah I know but I wanted to leave it a little bit longer so it doesn’t get in the way of any ecu programmer when I chip it in the future
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,530 21,697 234 Box behind Walmart Dec 13, 2018 #9 Dec 13, 2018 #9 Blown88GT said: They should be mounted close to the circuit board. Click to expand... ^this^ but I'm not sure it would make it 'better' to re-solder them.
Blown88GT Founding Member Nov 13, 1999 2,283 524 164 Palm Beach Gardens, FL Dec 14, 2018 #10 Dec 14, 2018 #10 Impossible to mount them close unless you wick the solder from the thru-holes.
