Anyone have wiring diagrams for ignition system?
zadan
27
Maryland
I am installing a tach in my 93 LX and I do not know which wire off the coil is the positive one. I thought I could use a test light to figure it out, but they are both hot when the engine is running and they are both cold when the car is off and in acc.
Headed to the track this Saturday, need my new Ford Racing tach to work right. Help!!
If I'm not mistaken the hot wire should red w/ a green stripe and I think the green wire has a red stripe. The factory wire harness has two green wires that come together. One is for the coil and the other is for the factory tach.
The Tan/Yellow wire is the feed for the tach on a 93 5.0. The other coil wire is Red with Light Green. If yours are different, then someone's made a swap into there. What's your VIN?
