Yep, very easy. Had on in my car before I did the 6 speed swap. I would recommend setting the neutral saftey switch and back up light switch BEFORE you ever get the shifter near the car. Use a continutiy meter or light and hook it up to the blades on the switch. With the shifter in P or N adjust the neutral safety switch until you have continuity. With the shifter in R adjust the back up light switch until you have continuity. Bolt in the shifter, bolt the braket to the trans, and adjust the cable.
