I did a gear swap in my 89, went from 2.73's ro 3.73's and it really wasn't too bad at all. You just had to have the proper tools and follow the instructions. The biggest thing was to measure the backlash before and after the gears are installed. One important fact that I heard when I was looking for gears is I was told if you're going to do the swap, buy FRPP gears. Why? Because they are all made to almost identical tolerences and when you remove the old gears and re-install the new gears, you shouldn't need to add/remove any shims, and still get nearly the same backlash as what you had before the swap (most of the time). Well that's how it turned out for me. If you have the tools, mechanical ability, and good instructions, you should be able to handle the swap. Just take your time and don't take any shortcuts. Do an internet search and you should be able to find some instructions on the swap. Good luck!
