I have an incon TT kit on mine. This is not an install you want to do yourself. Notching and welding the frame, and modifying the oil pan would be beyond my comfort zone. The rest is pretty straight forward.
I don't know what kind of power I'm making. I'm still on a stock lower end (including cam). I've got an extremely mild combo with stock compression, GT40X heads, and a GT40 intake. It is intercooled, and only pushes a 9.5 lbs of boost. I haven't taken it to the dyno, but my car traps 118 granny shifting at 5500 and staying off of the throttle in first and second so that I don't blow the tires away.
Without a doubt, the car would've trapped better than 120 if I could floor it in the first two gears. The car probably weighed 3400+ lbs with me in it at the time. So, that should give you some idea of power.
