Thanks. This was from a post on that forum:
This just in from someone that has done it down under. It's a Mitsubishi Starion box. He drills and crush tubes the frame rail and has the Mustang Pitman arm re-splined. Uses a manual center link or a P/S center link with the manual conversion kit. Just make sure pitman and idler are the same length. I assume you would locate it so that the pitman arm connection to the center link is at the same location as the original. 69 column with rag joint should work. You will need patience and a real good machinist. Nobody should recommend welding two pitman arms together.
I would be more comfortable with puting new holes in the frame to mount the new box to. Also, another post in that thread said it was from a Toyota Corolla. The regular Corolla uses a R&P unit while the Corolla DLX uses a box. I checked into an 82 Corolla.
A-1 Cardone PN 278571
