Anyone use a GM 3 bar map sensor?
I am currently using a LM-1 with rpm converter to track down some driveablity problems and wanted to reference boost with a couple of other sensors. I hooked up the Map sensor and I quickly realized that it wasnt going to work. I read up on Map sesnors and found out that what I have measures in Hz not voltage like I thought. I found that alot of GM vehicles use a 3 bar map sensor that is voltage regulated. Has anyone used a GM 3 bar Map on there mustang?? Is there a better way than going to the dark side and buying a GM product??
