Anyone use a 3 bar map sensor?
sweet88gt
334
Venice FL
Anyone use a GM 3 bar map sensor?
I am currently using a LM-1 with rpm converter to track down some driveablity problems and wanted to reference boost with a couple of other sensors. I hooked up the Map sensor and I quickly realized that it wasnt going to work. I read up on Map sesnors and found out that what I have measures in Hz not voltage like I thought. I found that alot of GM vehicles use a 3 bar map sensor that is voltage regulated. Has anyone used a GM 3 bar Map on there mustang?? Is there a better way than going to the dark side and buying a GM product??:D
Are you trying to hook a 3 bar up using just the stock EEC?
If so, that is not going to work. The EEC does not know what to do with boost signals from a 3 bar. You'll need a tuner capable of using those signals.
Thats what I wanted to do but I keep running into problems. All I really want to do is datalog boost pressure,tps,intake air charge,rpm,and mass air voltage. I dont need boost pressure I didnt figure it would be this much of a pain. I am still running the factory eec with a diablo chip. Ill just put that idea on the back burner for now.
You can still use the 3 bar to data log to something like an LM-1 AFR meter with RPM converter if you like, but the sensor you select needs to have a 5 Volt range and be in addition to your stock baro sensor (if MAF) or MAP sensor (if SD).
