Anyone use Seafoam????
  • Thread starter Thread starter 89budget50
  • Start date Start date Jan 7, 2004
89budget50
29
Dallas/Fort Worth, TX
Jan 7, 2004
  • Jan 7, 2004
I have an 89 with about 138,000 on it. I have been told seafoam works pretty good at getting rid of excess carbon in the engine. I was wondering with me having high miles is it even worth it. My car runs great now and I can't afford to hurt it. From what I have found, this stuff is supposed to be great though. Any suggestions?
83Rag
66
Kittanning PA
Jan 7, 2004
  • Jan 7, 2004
89budget50....
I was not too sure about that stuff either but, it worked real good on my '91 F-250 I-6!
HISSIN50
34
129
Jan 8, 2004
  • Jan 8, 2004
this is the thread from last year on it.
http://forums.stangnet.com/showthread.php?t=373915
C
CobraGT87
Mr. Speed Density
1,876
USA
Jan 8, 2004
  • Jan 8, 2004
I use Amzoil's Power Foam which is the same thing, plus I run their PI injector cleaner every other tank. (the screens inside the inj's can build up varnish from the junk they put in gas and cause a bad spray pattern) Stuff works great at keeping inj's clean and the foam works great at keeping piston tops, TB, etc clean. I use the Power Foam every 5k miles. Well worth the $8 a can for each one.
Take care,
Scott
89budget50
29
Jan 8, 2004
  • Jan 8, 2004
Thanks for the reply's guys. I think I am going to give it a try. I was looking at the vacuum diagram on one of TMOSS' sites and if I am looking at it correctly, do you think the hose all the way on the left closes to the engine would get to all the cylinders? If not, which one do you guys use? Thanks.
HISSIN50
34
129
Jan 8, 2004
  • Jan 8, 2004
Scott, real good info. i will give it a shot as well, based on what you have said. where do you get both of the products? thanks for the info.
ashford
485
fargo ND
Jan 8, 2004
  • Jan 8, 2004
if you can dump it directly into the intake it works the best. after you run about 2/3 or the can through wot it and dump the rest in making sure you kill the engine. let it sit for 5 min then start. it will smoke like noting you've never seen before. be prepared for a few people stareing like your car is a piece of ****. lol
C
CobraGT87
Mr. Speed Density
1,876
USA
Jan 9, 2004
  • Jan 9, 2004
I get mine at www.amzoil.com even though my local speed shops sells most all amzoil products. I bought their *perferred customer* program so I get a better discount on everything as I also use their syn oil, filters, trans fluid & rear end fluid. it's cheaper this way and delivered right to my house cheaper than if I went to the shop to buy it.
http://www.amsoil.com/products/api.html (PI Injector Cleaner)
http://www.amsoil.com/products/apf.html (Power Foam)
When you use the powerfoam, get the motor up to normal temps, then just loosen up the hose at the TB and spray the entire can in. the motor will almost die, so you might have to tap the throttle linkage to keep it running. when can is empty, shut off motor for 20 min, then fire up and load the motor good in 2nd gear a few times to clean it all out. If you see alot of white smoke, then it was gummed up inside.
Stuff works great and completely safe for all sensors etc.
Take Care,
Scott
LXMiker
159
Good ol' Wisconsin
Jan 9, 2004
  • Jan 9, 2004
sounds like too much work i think i will just dump some stuff in my tank....
89budget50
29
Jan 12, 2004
#10
  • Jan 12, 2004
  • #10
For those of you who have used seafoam or another similar product, what vacuum line did you use to get it into the engine?
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
O
Paint and Body Has anyone put 1990 GT Hatch body kit on a 1989 GT Convertible
  • obeone66
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2025
General karthief
