I can't seem to get a straight answer to if these will fit.
OK lets start up front.
17x9 +24mm 5.95" BS
SHould only get rub at full lock. Rack limiters should cure this. May consider runnins stock 17x8 offset.
Out Back
I really want to run 17x9's but i'm afraid it will stick out too far? Anyone running the +24 offset with SN95 track? Did you roll the fenders??
AFS wheels sells a 17x9 bullitt with a +26mm offset , 6.11" of BS. It's a little deeper but only by about 0.16". Do you think this would be enough to compensate??
If this turns out to be too much of a PITA, i'll just run 17x8 bullitts. I really wanted to run the 17x9's because of the slightly larger lip and the higher polished finish you get with aftermarket bullitts.
PS. I am planning on running black bullitts, but am also considering anthracite bullitts, '98 Cobras, 18" Saleen wheels and 03-04 GT premium wheels (the chrome '01 Cobra wheel).
17x9 +24mm 5.95" BS
Out Back
