anyone with AOD & Lokar Kickdown..need help
  • Thread starter Thread starter DPMAZ
  • Start date Start date Jul 19, 2005
D
DPMAZ
52
  • Jul 19, 2005
Did I do this right? I hooked up a pressure gage at the T.V. port on the trans...at idle in Neutral I then set the pressure at aprx. 35lbs..This info on the process on got off various posts about how to do it here and else where, butthen I read LOKARs instruction ansd they say you need some sort of gauge block to slip between the plastic housing on the cable and the end of the cable that has the set screw...whats the deal, did I just do this for nothing and need to order this gage block...Please clue me in...
Don
thehueypilot
1,084
Medina,Tennessee
Jul 20, 2005
  • Jul 20, 2005
Don
I think I would use a transmission builders adjustment procedure vs. a cable company. Try Lentech's web site for detailed instructions for adjustment.
chepsk8
2,203
Easton, PA
Jul 20, 2005
  • Jul 20, 2005
And to think when I did it, I just kept adjusting it until it shifted nicely!
ericl
41
Wisconsin
Jul 20, 2005
  • Jul 20, 2005
When I first set my aod up I had a guy from the local dealership come and set it up. He said they typically put a block of some sort under the throttle linkage (to get the correct throttle position) While it is in neutral. Then they set the pressure at 35-40 psi. This is a BIG difference from Lentech's instructions. Lentech recommends 3-5 psi at idle in PARK.
thehueypilot
1,084
Medina,Tennessee
Jul 21, 2005
  • Jul 21, 2005
I'm not sure why you would need that much pressure at idle?
D
DPMAZ
52
  • Jul 21, 2005
I finally set it up according to lokar, I called them and they told me that the gage blok they reference in the instructions is .275 so basically they said put a bolt or something that is .275 with a slot in it to slip over the cable between the cable end and the plastic piece and set it to 36lbs.. I did this and it shifts better, seems about right.. it took about a half hour to do everything..
Edbert
3,548
32
109
Austin TX
Jul 22, 2005
  • Jul 22, 2005
The .275 then is essentially the slack in the end of the cable?
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
