  • SN95 4.6L Mustang Tech
Anyone with experience with Synchromesh ATF?
  • Thread starter Thread starter stangGT97
  • Start date Start date Dec 29, 2004
stangGT97
1,299
Boston area, MA
Dec 29, 2004
  • Dec 29, 2004
I am looking for a better man-tran fluid because the Castrol Dextron fluid i have sucks. I was looking on Steeda.com at the synchromesh fluid, and they say it is the best fluid you can buy for a Tremec tranny, and that the T-45 will shift smoother. Can anyone validify this?
F
fr96ss
326
Long Island, NY
Dec 29, 2004
  • Dec 29, 2004
i have it in my 3650 havent been able to drive it though much because of the weather so i cant give you an accurate description of how it feels i have the syncromesh friction modifyed stuff in mine.
Blown9SecStang
Canada
Dec 29, 2004
  • Dec 29, 2004
I'd go with either the Redline MTL Fluid or the Royal Purple Synchromax Fluid.
YardSpecial
2,664
MT
Dec 29, 2004
  • Dec 29, 2004
Good advice !
I ran the RP and loved it over Mobil 1 SYN ATF !
stangGT97
1,299
Boston area, MA
Dec 29, 2004
  • Dec 29, 2004
is all of this stuff available at autozone and other automotive stores or is it special order? Also, if a transmission fluid works well with the 3650, does that necessarily imply it working well with the T-45?
YardSpecial
2,664
MT
Dec 29, 2004
  • Dec 29, 2004
DUDE !!
ALL THE SAME !!!!
RP, Red Line and GM Syncro is the best.
Factory just throws in cheap old ATF in.....
stangGT97
1,299
Boston area, MA
Dec 29, 2004
  • Dec 29, 2004
alright, thanks a lot... I'll be getting some GM synchromesh because I've heard several cases where it virtually eliminated 1-2 grinds on the T-45. Thanks for all the input!
01LaserRedCobra
318
  • Dec 29, 2004
This is from Tremec's site....
http://www.ttcautomotive.com/English/faq/faq.asp#14
Q. What type of lube is recommended for my TREMEC transmission?
A. The following types of lube are recommended:
TR-3550/TKO - GM Synchromesh or Dexron III
TR-3650/T-45/T-5 - Dexron III
T-56 (Ford and GM) - Dexron III
T-56 (Viper only) - Castrol Syntorque
YardSpecial
2,664
MT
Dec 29, 2004
  • Dec 29, 2004
Dexron is a waste of money and time one all trans.........
GM fluid has been the choice for some time now, just $$$$
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 30, 2004
#10
  • Dec 30, 2004
  • #10
I use Mobil 1 ATF and it works great.
twogts4us
4,188
12
79
Dunedin, FL
Dec 30, 2004
#11
  • Dec 30, 2004
  • #11
Mobil 1 ATF here too...made quite a difference...I was really surprised. Syncromesh is the recomended fluid, but Mobil 1 is more readily available and is a brand I (and most of us) trust.
281Ponies
190
#12
  • Dec 31, 2004
  • #12
Same here about two weeks ago I changed the fluid at 30k and used Mobil1 ATF the difference is Very noticeable.
-Cale
YardSpecial
2,664
MT
Dec 31, 2004
#13
  • Dec 31, 2004
  • #13
Mobil 1 is risky to use..........
RP is at Napa, GM Fluid is at the dealer, safer choices to use.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 31, 2004
#14
  • Dec 31, 2004
  • #14
The GM synchromesh fluid is just fine to run. I used to use it in my T-5 all of the time. No issues with it and it reduced that cold run grind from first to second and second to third that I used to get just running regular ATF. I've got buddies that run it in their T45's and 3650's also.
40th GT
916
Lawrenceville, GA
Dec 31, 2004
#15
  • Dec 31, 2004
  • #15
Can you or someone else explain why this is so?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 31, 2004
#16
  • Dec 31, 2004
  • #16
ya i would like to know why mobil 1 is risky to use. and the napas in my area dont carry RP.
Mustang5L5
Mod Dude
Feb 18, 2001
43,335
18,060
224
Massachusetts
Dec 31, 2004
#17
  • Dec 31, 2004
  • #17
Transmission fluid is NOT all the same. This isn't a matter of buying whatever is on sale that week. The transmission is designed with a specific fluid in mind. The reason being each fluid has different properties and flow characteristics that are taken into account when creating the tolerances and synchro materials inside the trans. WOuld you guys ever run 15w-20 in your engines when Ford states to use 5W-30?? So why is it any different for transmissions?
The ONLY Tremec trans that you are supposed to use Synchromesh with is the 3550/TKO. Everything else takes DexIII ATF.
If you get away with switching fluids, fine go ahead. The paper lined synchros in the T-5 and t-45 don't really work well with synchromesh but if everything "feels" ok then it must be fine.
But like i said, trans fluid is not all the same.
YardSpecial
2,664
MT
Dec 31, 2004
#18
  • Dec 31, 2004
  • #18
Mobil 1 is TOO SLIPERY
All oils are slippery, and with most lubricated
components, the slipperier the better, but this is not so
with manual transmissions. The synchronization of
shifting gears requires friction to transfer energy from the
synchronizer, which is locked to the input shaft, to its
mating surface attached to the gear to be locked in as
the drive gear. Few modern transmissions use sliding
gears to change gearing other than for reverse gearing.
Synchromesh transmissions have the gear pairs constantly
in mesh. The drive gear is selected by using the
shift forks to slide a synchronizer ring, which rotates at
the same speed as the input shaft, in contact with the
selected drive gear. Once the drive gear is brought to
the same speed as the input shaft, the locking ring on
the synchro assembly is allowed to slide over and lock
into the drive gear.
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
P
Drivetrain Where to buy T5 synchros only, don't need full rebuild kit
  • pindude80
  • May 8, 2024
3K
Fox 5.0 Mustang Tech May 25, 2024
Mustang5L5
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
