anyone with pbrake freezing or getting stuck when cold
2003gt
290
Brandon, MS
anyone having this problem.....i have had the ebrake on when parked overnight and it was "locked" in the morning....not too cold here lowest was 37 but after warming car up, then driving slowly down the street, it would slowly loosen up to where it was supposed to be....??
I had this problem early this winter. Dealer replaces both cables under the aforementioned TSB, but was stingy, in my case, about replacing your now-probably-overheated brake pads and rotors. Good luck
E-brake
This is getting to be a very common problem. I wonder if Ford has changed the brake cables in any way to keep it from happening again-I hope so. If not, the second time it happens, the cars will be out of warranty. Anybody know if there has been a design change?
The new one is a much more sturdy looking piece. The problem I noticed with the old cable was the rubber boot where it attaches to the rear caliper was completely dry rotted, and would let water get in and freeze. They also turned the passenger rotor and replaced the brake pads.
There is a TSB on this, had mine replaced last week and no problems since. It is the seal at the rear of the cable, lets water get in.
