- Mar 1, 2008
- 105
- 0
- 16
Anyone have a serpentine setup with these components?? Crank, waterpump, smog pump eliminator, a/c eliminator kit, and power steering...on a fox... and if u do wat belt size u runnin?
you eliminated your crank and water pump?
if you want any chance at an answer,... you really need to re-phrase that to be a little more clear.... just my 2c.
belts do stretch a tiny bit while under heavy acceration....cost me 2 40 dollar belts a long time ago before I caught on.....
ouch that blows to go through 80 dollars in belts! I believe my belt is 2 small b.c right away on start up, the belt will walk off the smog pump eliminatorand will be off by about 2 grooves.. so i will try the string thing and c wat i can come up with! thanx again guys
well uk the alignment marks on the tensioner its like a big long rectangle? (well not really that big) the pointer points on the very right corner of of it so its kinda down far. (tensioner pulley is more down toward the ground)
well it feels tight but the tensioner is i believe is about maybe a little more than a quarter of its tensioningness....(thats a word isn't it?) O OK better word...travel... a little more than a quarter of its whole travel
