K krallman New Member Mar 3, 2006 96 0 0 Hurricane, WV Oct 25, 2006 #1 Oct 25, 2006 #1 i was wondering if there is anyway to lock the aod in my 85 in second gear. i only need second gear cause its only purpose is racing cirlce track.
Snikt89GT New Member Sep 6, 2006 264 1 0 Deland, Florida Oct 25, 2006 #2 Oct 25, 2006 #2 Nope, you would need a manual for that
ninety15.0 New Member Mar 10, 2004 1,336 0 0 Oct 25, 2006 #3 Oct 25, 2006 #3 i dont own an AOD but i think you can do the 1-D-1 shuffle...start in first shift to D and then shift back to 1. should hold 2nd
Snikt89GT New Member Sep 6, 2006 264 1 0 Deland, Florida Oct 25, 2006 #4 Oct 25, 2006 #4 ninety15.0 said: i dont own an AOD but i think you can do the 1-D-1 shuffle...start in first shift to D and then shift back to 1. should hold 2nd Click to expand... I've heard of that, but isn't it really bad on the tranny?
Glaze New Member Apr 3, 2005 133 0 0 Gainesville, GA Oct 25, 2006 #5 Oct 25, 2006 #5 yes its hard on the tranny....proper way to fix this is to get a manual valve body installed in the aod and an aftermarket shifter such as B & M unit.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,392 18,135 224 Massachusetts Oct 25, 2006 #6 Oct 25, 2006 #6 Snikt89GT said: I've heard of that, but isn't it really bad on the tranny? Click to expand... Yes, holding it in second by shifting back to 1 will overheat the trans. I beleive the OD band is being engaged when you do this
ninety15.0 New Member Mar 10, 2004 1,336 0 0 Oct 26, 2006 #7 Oct 26, 2006 #7 Mustang5L5 said: Yes, holding it in second by shifting back to 1 will overheat the trans. I beleive the OD band is being engaged when you do this Click to expand... no, i dont believe thats the case. Honestly i dont think there is anything wrong with this method. It just takes time and practice before you get it right.
