  • 1994 - 1995 Specific Tech
AOD & AODE
  • Thread starter Thread starter law
  • Start date Start date Dec 30, 2003
1 of 2 Next Last
L
law
290
  • Dec 30, 2003
What is the difference between AOD & AODE? If there is a difference, how can you tell which one you have?
Killercanary
The car that set the bar.
Altoona, PA
Dec 30, 2003
  • Dec 30, 2003
94-up came with the AODE, 93-older came with the regular AOD. The AODE is electronically controlled.
L
law
290
  • Dec 30, 2003
Oh I see...thanks for the response.
L
law
290
  • Dec 30, 2003
Nice car by the way...I have a question about gears. I also have an automatic and I was planning on getting gears for my first official mod. I did some research and found that manual should get 3.73's and auto should get 4.10's. I saw that you upgraded to 4.10's fairly recently. Would that be the way to go for me also even though I drive it as a daily driver?
H
HazMat404
1,749
Dec 30, 2003
  • Dec 30, 2003
well i put 4.10's with my auto then i swapped to a manual and i would want nothing less. in the auto it is sooooo great
gcomfx.com
3,690
Republic, MO
Dec 30, 2003
  • Dec 30, 2003
I went with 3.73s myself. How much Highway driving do you do?
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Dec 30, 2003
  • Dec 30, 2003
I did 3.73's way back..Best NON power adder mod EVER!
I did a lot of highway driving then so I was fine. Now, with the Vortech, Im glad I did NOT get 4.10's...I spin like crazy as it is.
If you are going from stock, you will LOVE 3.73 and be satisfied with them.
AOD=shifts controlled by mechanics of the tranny.
"E" = Electronic...Computer controls the shifting...this is really nice when using a chip or TwEECer.
RC
huskerpower02
770
KS
Dec 30, 2003
  • Dec 30, 2003
RC
So 3.73's it is. How off is your speedo?
-Drew
gcomfx.com
3,690
Republic, MO
Dec 30, 2003
  • Dec 30, 2003
Mine is about 9mph at 70... so it says 79mph but I'm doing 70mph. This will add miles to your car.... ugh. But it's not Too annoying for the performance gain you get.
Edit.... that was when I was running 16 in wheels. I should probably RE-check it now that I have 17s.
94GTLaserRC
11,178
Dec 30, 2003
#10
  • Dec 30, 2003
  • #10
with the speed-o gear, Im off about 10%...but the OTHER way. When my gauge reads "70, Im doing about 77-78. I measured the miles once on the hwy by the markers, and when the mile markers hit 15, my odometer had turned 13.5 miles.
I guess I have a few more miles than the odom. shows.
Also, my 13 mpg is really more like 15.
RC
baseman
Providence, RI
Dec 30, 2003
#11
  • Dec 30, 2003
  • #11
Is there any way to compensate for the gears, and make the speedo and odometer correct again? If so, what are the options?
gcomfx.com
3,690
Republic, MO
Dec 30, 2003
#12
  • Dec 30, 2003
  • #12
Lots of money in a box that converts the signal. Others will have more info... but it was TOO much for me to spend just to correct a little problem.
94GTLaserRC
11,178
Dec 30, 2003
#13
  • Dec 30, 2003
  • #13
Just live with it...Im pretty ANAL, and I did.
BTW...WELCOME TO OUR BOARDS!!!
RC
baseman
Providence, RI
Dec 30, 2003
#14
  • Dec 30, 2003
  • #14
RC
Thanks RC... great to be here!
Q
QCStang
813
Aylmer, Quebec, Canada
Dec 30, 2003
#15
  • Dec 30, 2003
  • #15
You can get a little plastic gear with different teeth. About $20, and it plugs in the tranny housing. Resto5.0 carries them.
Welcome to the gang. Most of the guys that do all the yakking in this board seem to be from Florida (?)....
gcomfx.com
3,690
Republic, MO
Jan 2, 2004
#16
  • Jan 2, 2004
  • #16
I've got supposedly the closest one (tried 2)... you'll still have to learn to live with it if your an AODE owner.
Mrgreen94gt
SIMMA DA NA!!!
448
West TN
Jan 2, 2004
#17
  • Jan 2, 2004
  • #17
I just used the Speedcal. It gives me that extra peace of mind that the speedo is accurate, which is nice considering all the highway driving I do.
95five-0
145
Mountain Home, ID
Jan 2, 2004
#18
  • Jan 2, 2004
  • #18
All of this talk about gears lately. Can anyone tell me what the stock gears for a 95 GT AODE is. Thanks.
FastmanGT
587
Oklahoma City, Oklahoma
Jan 2, 2004
#19
  • Jan 2, 2004
  • #19
3.27 is the ratio they used for the aod-e cars, but I have read about 3.08 gears in some. To test it, put the rear of the car in the air and spin one of your rear tires once and count how many times the driveshaft spins.
94GTLaserRC
11,178
Jan 2, 2004
#20
  • Jan 2, 2004
  • #20
HHmmmm...now let's see, did it spin 3.27 times, or 3.08 times
RC
1 of 2 Next Last
D
Ford AOD Transmission filler tube orings
  • Dagasser
  • Jul 21, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 26, 2026
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
A
Drivetrain 91 AOD linkage at transmission
  • alchemist1
  • Sep 29, 2025
Fox 5.0 Mustang Tech Sep 29, 2025
JD1964
