AOD Deep Pan Clearance
  • Thread starter Thread starter gungfusemaj
  • Start date Start date Jun 7, 2009
gungfusemaj
211
Bradenton Fl
Jun 7, 2009
  • Jun 7, 2009
Im going to swap out my stock AOD Pan for a deep one and wanted to know if there is any clearnce issues with exhaust or any thing else that I may run into if I swap it out for a deeper one?
Thanks 87gt
RYC CUKR
1,437
Orlando
Jun 7, 2009
  • Jun 7, 2009
I have a deep pan on my AOD and a BBK O/R x pipe. Its tight but it doesn't rub or hit. If it didn't have a drain plug in the pan I would have to drop the x pipe to change the trans fluid though.
gungfusemaj
211
Bradenton Fl
Jun 29, 2009
  • Jun 29, 2009
Ok that brings me to my next question, How many quarts of fluid do I need for a Aod with PA Deep Pan. I got the Deep Pan in the other day and one of the main reasons I am changing it out is because I would like a drain plug .that is one of the nastiest jobs Iv have done ,
My Pony has been sitting for about 2.5 years I have charged the battery and moved it around the yard a couple of times, but on the road it hesitates big time before catching in gear like it is low on fluid but she's pretty full and it does this even backing up and then putting it into drive.
Is there a recomended AOD Tranny restore fluid or anything else I can do to help, The Tranny was perfect before I had bought a house and a whole lot of bs of life events happened.
I guess my point is I dont want to do all that work for nothing, Im simply changing the Pan and not make my first mistake and letting the seal set for 24 hrs before adding fluid so it doesnt leak, but before I go and drop x amount of qrts in I wanna put the good stuff in.
87 gt
gungfusemaj
211
Bradenton Fl
Jul 10, 2009
  • Jul 10, 2009
RYC CUKR
1,437
Orlando
Jul 10, 2009
  • Jul 10, 2009
Are you doing a complete fluid change, meaning draining the converter, or are you just going to drain the pan and change the filter?
For a full fluid change I believe it is around 12 quarts for the stock pan. My pan added around 3 quarts.
For just a simple drain the pan, change to the deep pan would probably be about 6 quarts but get a few extra JIC.
gungfusemaj
211
Bradenton Fl
Jul 12, 2009
  • Jul 12, 2009
Thanks
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
