AOD Help!
  • Thread starter Thread starter 1bad89lx
  • Start date Start date Feb 14, 2009
1bad89lx
134
Angola, IN
Feb 14, 2009
  • Feb 14, 2009
I recently bought an 87 GT with the AOD. The car shifts perfect and pulls hard in both first and second gear but turns to mush and slips in overdrive. It appears that the tv cable has been messed with before. I picked this car up for cheap and just want to have it as a toy. I'd rather not dump a bunch on money in it.
My questions are:
1) How likely is it that overdrive goes out but the other gears shift fine?
2) What would the results of a bad tv cable be?
3) Should there be tension on the tv cable itself?
Thanks in advance for any help/ideas you can offer.
TwoToneHatch
170
New Jersey
Feb 14, 2009
  • Feb 14, 2009
I can't really help you with the TV cable because i haven't messed with mine.But if your overdrive is wiped it could be the result of one to many 1-D-1 AOD shuffles.
JGT
Charleston, SC
Feb 14, 2009
  • Feb 14, 2009
That is a myth!
TwoToneHatch
170
New Jersey
Feb 14, 2009
  • Feb 14, 2009
JGT said:
That is a myth!
Is it? Well I guess you learn something new everyday. I've always been told that the 1-D-1 fries your OD band.
90 lx convert
Stanger
926
Falling Waters Wv.
Feb 14, 2009
  • Feb 14, 2009
The main problem with the AOD is that it was built to be a luxury car trans and yes the AOD shuffle is hard on it in stock form. When it shifts into 2nd 1st gear is actually still releasing pressure on the clutch pack. This allows for a seamless smooth shift. Not exactly what we are looking for in a performance trans. The TV cable should not have any slack in it. It should move as soon as the throttle does. The TV cable tells the valve body how far the throttle is open, the valve body then adjusts the shift firmness and rpm point of shift. If it's been driven far with the clip broken on the cable or way out of adjustment it will hurt it. I've broken 2 so far, 1 on the dyno even. The latest one with the manual valve body, trans brake, kevlar clutches and forged internals has gone 3 yrs without an issue.
SPEEDYLIFSAVR
666
FL,89 LX 5.0
Feb 14, 2009
  • Feb 14, 2009
Likely...happened to my AODE but usually the other gears wont be far behind!
tranny not shifting properly!
Cable should be taught , do a visual inspection and make sure none of the clips are broken and it is properly hooked to the bottom of the throttle body and it is not loose .
If the tranny is fried it is not too bad of a job , I replaced a few in my garage on jackstands . You can save money by dropping it yourself and taking it for a rebuild or buying a remanufacture . I would recommend atleast a shift kit possibly even a mild stall and definately a tranny cooler . Or you can just swap over to a T-5 and row some gears!!
L
lang williams
567
cleveland, oh
Feb 14, 2009
  • Feb 14, 2009
check out Click Click Racing good aod site, lots of troubleshooting info. you can find out how to check your tv pressure with a 100 psi oil pressure guage or how to set it without a guage but its not as accurate.
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Aod to t5 swap will it live?
  • 87slow.0
  • Nov 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2024
87slow.0
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
