AOD in 66 Mustang Wiring
Fredo
115
Byers,Co
Anyone had experience wiring in the backup light and neutral safety switch on a Aod conversion in a 66 Mustang? I have the sensor on the AOD and the the harness that originally came with the AOD, but the wires were cut. How do I wire it into my system? Need help!:shrug:
Use a schematic to get the wire colors of the car side of the two plugs on the harness. Then, go to the transmission and put it in reverse. Use a meter and check the wires to see which two have full continuity between them. That would be the back up lights. Wire that into the ones you found from the schematic (http://hammar.dyndns.org/~djhamma/wiring/1966/66exter1.jpg)
and you should have back up lights. Doing the same splicing for the other two for the neutral safety switch and you should be good to go.
