Aod Or 4r70w? Which Is Better?
  • Thread starter Thread starter V8_Kind_Of_Guy
  • Start date Start date Sep 6, 2012
First Prev 2 of 2
F
Fox8950
247
Sep 11, 2012
#21
  • Sep 11, 2012
  • #21
From what I've come to understand after rebuilding a couple the major flaws on the AoD boil down the the tiny 3/4 secondary input shaft, roller sprag, and the stupid band that engages the overdrive is easy to torch if you are beating on it all the way into OD. They have 1 piece input shafts for AoD but the 3/4 shaft is your converter lockup so 1 piece shaft = no lockup and lots more heat on the street, hardened input shaft would be way to go on a street car imo but as you feared even the hardened ones have a bad history once u put power to them. Roller sprag is easy fix they make a diode that is lots stronger. And the only good fix I have seen for the week OD band is don't do any (well many) flatfooted shifts into OD. I only have 400ish hp to mine so not taxing it a ton but its alot of fun with transgo shift kit, chirps em right into 3rd. If I had it to do over again I would probably go with a 4r70w build after seeing the weaknesses of the AOD but like I said I don't make enough power to brake mine since I upgraded it. Not even positive a 4r70w would be better have yet to mess with one, but sure looks better on paper.
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 11, 2012
#22
  • Sep 11, 2012
  • #22
This is what has made my AOD very streetable. It works so well you can "feel" a temperature difference between the input and output of the cooler.
http://www.dieselsite.com/specialordertru-cool4739transmissioncooler.aspx
F
Fox8950
247
Sep 12, 2012
#23
  • Sep 12, 2012
  • #23
Well aside from all the bad things I heard about the heat from non-lockup converters does having no lockup on yours make the OD ratio different? My main deal was I do alot of interstate driving and figured constant slip at interstate speeds would = cooked even with an enormous cooler. Whats your experience with highway/interstate driving with the non-lockup?
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 12, 2012
#24
  • Sep 12, 2012
  • #24
Heat is usually never an i
Heat has never been an issue for me. Snapping the input shaft when i left the OverDrive switched on and downshifted to 2nd and hammered the gas did once. (Snapped the 3/4 shaft)
With a good stacked plate cooler you should be able to run anything you want. Your first easiest and probably cheapest transmission MOD should be the largest stacked plate cooler you can fit behind the grill.
V8_Kind_Of_Guy
73
Denver, Co
Sep 12, 2012
#25
  • Sep 12, 2012
  • #25
Havent heard of transgo, Ill have to look into them. And a trans cooler, I thought about going onto summitracing and getting one of the biggest ones they offer.
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 12, 2012
#26
  • Sep 12, 2012
  • #26
Get a TruCool. All Aluminum stacked plate. The truck guys rave over them towing boats and campers. They get rid of heat fast.
V8_Kind_Of_Guy
73
Denver, Co
Sep 12, 2012
#27
  • Sep 12, 2012
  • #27
ok, I'lldefinitely look into them.would you recommend a fan on the cooler?
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 12, 2012
#28
  • Sep 12, 2012
  • #28
Not really if you put it infront of the radiator. Adding one wouldn't hurt either but isnt necessary.
FoMoCo17
188
Sep 14, 2012
#29
  • Sep 14, 2012
  • #29
Get the 4R70W it has all of the upgraded goodies already that they put in the AOD's. It has the ratchet one-way clutch, upgraded direct drive drum, steel drums, better servo and bands sizing etc. and the ability to hold more clutches/steels. its a better foundation to add on in doing a build. I also used a non-lockup converter in my AOD as recommended by Hughes because the lock-ups cannot handle horsepower is what I was told. They also told me that they pretty much act like a lock-up since they are near lock-up 96-98% without the failure.
V8_Kind_Of_Guy
73
Denver, Co
Sep 15, 2012
#30
  • Sep 15, 2012
  • #30
I'll definitely get the 4r70w now. I also was told that the non lock up was stronger, my worry has been highway driving though. I'm still a little confused when people say lock up can't take the power, do you mean in general at any time, any gear without it locked up or just when the convertor is locked up?
First Prev 2 of 2
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
