aod problems
  • Thread starter Thread starter low5.0
  • Start date Start date Jul 28, 2004
L
low5.0
54
las vegas
Jul 28, 2004
  • Jul 28, 2004
when i come to a stop and then try to go again it slips out of gear.it revs up and when i let off and give it gas again it goes back into gear.if i slow down,turn and then give it gas it does the same thing.could i just get a shift kit or do i need a rebuild.cant really afford the down time but probably can get it done cheap.sorry its so long.
The Shape
2,224
East ARKANSAS Delta
Jul 28, 2004
  • Jul 28, 2004
First thing to check with those symptoms is the fluid level.
L
low5.0
54
las vegas
Jul 28, 2004
  • Jul 28, 2004
thanks a lot The Shape.i just changed the fluid and filter and didnt read the manual well.
timewarped1972
642
mesa, az
Jul 28, 2004
  • Jul 28, 2004
make sure you check the fluid with it idleing in park after it's warmed up for a few minutes......try not to over fill it either, with a filter change your probably lookin at about 5 quarts worth, give or take a little.
shttygtstang
978
  • Jul 28, 2004
i hate to be the bringer of the bad news your band is most likely toast or pump mine just did this 3 weeks ago had to have the whole thing rebuilt for it to stop slipping for alittle while days maybe add a half a bottle of dot3/4 it swells the seals and cluthes
shttygtstang
978
  • Jul 28, 2004
converter alone takes 4 quarts 5 quarts is way off
347 Special
78
las vegas
Jul 28, 2004
  • Jul 28, 2004
If the fluid is ok, then start saving ITS TOAST. same symptoms on my AOD when they went out.
P.S. low5.0 just saw you are from vegas also do you associate w/ any car clubs in town??
shttygtstang
978
  • Jul 28, 2004
im looking at it this way if hes down on tranny fluid he most likely burt somthin out.if hes full then somthin is burt out
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jul 29, 2004
  • Jul 29, 2004
mine did tha same before it crapped out on me... when i'd hit tha gas it'd come out of gear... damn thing only lasted me 20,000 miles after it was rebuilt! damn AODs... finally gave me a reason to convert tho... thanks AOD
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
