aod problems
low5.0
54
las vegas
when i come to a stop and then try to go again it slips out of gear.it revs up and when i let off and give it gas again it goes back into gear.if i slow down,turn and then give it gas it does the same thing.could i just get a shift kit or do i need a rebuild.cant really afford the down time but probably can get it done cheap.sorry its so long. :shrug:
make sure you check the fluid with it idleing in park after it's warmed up for a few minutes......try not to over fill it either, with a filter change your probably lookin at about 5 quarts worth, give or take a little.
i hate to be the bringer of the bad news your band is most likely toast or pump mine just did this 3 weeks ago had to have the whole thing rebuilt for it to stop slipping for alittle while days maybe add a half a bottle of dot3/4 it swells the seals and cluthes
converter alone takes 4 quarts 5 quarts is way off
mine did tha same before it crapped out on me... when i'd hit tha gas it'd come out of gear... damn thing only lasted me 20,000 miles after it was rebuilt! damn AODs... finally gave me a reason to convert tho... thanks AOD
