AOD speedo gear ok to use in C6?
AOD and C4 speedo gears are the same, or both fit either. Not sure about C6's, but if you put them side by side, and the teeth are cut the same way and they fit, they should work. To be sure, you could ask a dealer parts guy to cross check the numbers.
