AOD swap in a 69 Mach 1
wyomustang
Tulsa
Want to go with an AOD in my 69 mach 1 , what are the Pros and Cons. Any Good sites to help with my decision. and Will an AOD out of a 87 Cougar work. I'm running the 4:11 rearend that I discovered in the car. how will the AOD work with that set up? Thanks John
chepsk8 did this very swap a few years ago so you might pm him about the swap. with 4:11 gears i would definitely go with the AOD swap. as long as the AOD comes from a 5.0 powered car you can use the transmission. you will need a flexplate with the proper 28oz balance factor. summit racing has them at a reasonable price. you must also properly hook up the throttle valve cable or you will burn up the trans in short order. lokar has the cable you need.
wyo I'm just doing this myself....like...right now!....i know mines a 68', but I'm going to sit down a write up a tech article on here with some pics and general info...give me a bit and i should have it up.
