aod to t-5 question
lmarinukjr
75
ok heres the deal and yes ive searched.i have 2 mustangs both aod cars but one was hacked for a carb. setup.i have a clean 89 notch and a rusted beat 92 hatch.both 5.0's. i'm thinkin about taking the wiring out of the hatch and putting it in my notch and converting the car to a t-5. i have the double hump trans mount thingy and clutch pedal setup .its been a while since i went down to the cars does the double hump just bolt in? is there a write up with pics anywhere?i think ill be able to handle the wiring when the time comes i just want to make sure i have all my bases covered before i jump in.this will be a 2 or 3 year project but im very anal about things my son will be riding in.this project will be a complete build fresh motor fresh trans fresh rear. all the suspension all new interior and bolt on mods.
thanks in advance
My notchback was a 2.3L auto car. I made it a 5.0L stick car. Very easy.
You will need the T-5 double hump crossmember. It bolts in with no modification.
The pedal box is the most challenging because you are working in a confined space.
Changing the harness for the transmission is easy too. It unplugs at the left kick panel.
Any other questions ask me..I did the swap.
