AOD to T-5 woes...help?
89projectstang
64
ok, im having problems getting the bolts off of the driveshaft...whenever it feels like the nut is about to break, it slips. there are only 4 bolts to the driveshaft right?
any suggestions on what i can do!?
matt
What tool are you using?
You do know that these are 12 point bolts. don't you?
I think they are 12 mm.
If you are using a 6 point socket or an open end wrench it won't work!
And I put Loc-tite on them so theydon't fall out.
And they are usually TIGHT!!!
Bruce
yes there is only 4 bolts, i think its a 12 mm or 1/2 inch something around that size and you have to use a 12 point box end wrench or socket. if there stripped then Good luck, Also put anti seize on them when they go back in.
heh,
figured it out,
i was using a 1/2" 6 point socket and it just wouldnt work. i went to the local AutoZone (right down the street, no joke...like 4 houses away) and got a 12 point socket set. Using a 12 mm 12 point socket with a breaker bar did the trick... i was just about to give up to!!
thanks for your help!
matt
