AOD to t-5
quick question on clutch pedal assembly. i got a 90 gt with an AOD and want to put in a T-5. Will the pedal assembly from a capri work and if so what years. And what years of mustangs can you use? I know the 87-93 mustangs with a 5.0 with a will work. Will a 4-banger assembly work? I've searched for this and cant seem to find anything. any help would be greatly appreciated. :nice:
the clutch arm on a 4cyl assembly is a different length, i cant remember if its longer or shorter but it is different. Not saying it wont work but you may have to use a 4cyl clutch cable if you use a 4 cyl pedal assembly
Dr.
the 4 cylinder pedal assembly is no different than the v8.
there was a certain year in the 80's where the design changed, maybe 82 or 83, but any later year model, four banger or not, the pedals are the same.
the difference is where it connects at the tranny end.
