AOD to T-5
Greetings.
my car is a 1988 Mustang GT
i have full exhaust and a 190lph holley fuel pump done so far next is a fuel pressure regulator cuase my car runs really rich and back fires.
any way im starting to gather peice for a AOD to t-5 swap
can any one give me a DETAILED list of EVERYTHING needed?
i know the basics like
the tranny (duh)
bell house
clutch
flywheel
drive shaft
shifter
clutch pedal assembly
wiring harness ect.
i did this on my 86 GT, but i skipped the "blow up the t5 6 months later anyway" stage and went right with the tremec TKO. if youre using a stock used t5 and/or have anything peppier than a stock 5.0, consider that.
you will need....
bellhousing with the clutch fork and bellhousing bolts (i believe they are different length).
transmission with shifter assembly.
flywheel from a 1982 or later 302, only those had 50oz balancing.
flywheel and clutch bolts, 6 of each.
clutch disc, pressure plate, throwout bearing, and pilot bearing.
clutch pedal assembly and cable assembly
i dont recall if driveshaft length is the same or not, or crossmember either.
quality ATF fluid.
console trim plate, boot (upper and lower) and floor plate, shifter knob
i kept running mine on my stock speed density computer for the AOD, later when i switched to mass air, i still ran an automatic computer as i got one free.
i never bother wiring back up lights or nuetral safety switches, and its never bothered me. if you dont, you have to run a little jumper wire between two of the wires that went to the AOD's nuetral safety
a speedometer gear for the trans to match your rear end ratio, if its different and likely is. 5 speed cars most often had 2.73 gears, autos typically had 3.27's
driveshaft and crossmember are reusable, though the crossmember has to have the tack welds on the tubes ground off and moved. you may find it easier to just get another crossmember, but i made the stocker work. also for bellhousing bolts, the stockers work fine except the top two need some washers as those bolt holes are shorter. also make sure you have the correct block plate.
speedo gear is an interesting topic, because it will all depend on the gears in your rearend. you may possibly end having to get both driver and drive gears to fit your application, as later t5's switched from a 6tooth to a 7tooth drive. youll be best google-ing a chart to see what combination you need.
you can run a manual on an automatic computer and be fine. you can get problems if you run an automatic on a manual computer though.
like i said, i ran my tremec 5 speed with both the original speed density computer for an automatic and then a mass air computer for an automatic. never an issue
when i did my t5 swap the crossmember bolted right back up the studs were at the very end of the slot but it fit perfect without grinding the tacks off.
and yes the DS will work but i DO NOT recomment using it!
inside the splines of the AOD yoke there is a ring and it prevents the tailshaft of the t5 from seating it all the way. it makes the DS a tight fit, at least mine was, i had to hit it on with hammer it almost didnt go on, then i bought an alum DS after fighting vibrations and have been happy since.
on my car i plugged the plug under the car into the t5 and it works fine, my backup lights work good!
the car will run without a NSS, i didnt use it, BUT you wont be able to pull KEOR codes. it wont give you codes if the NSS isnt functional. i can start the car in gear and its helped me alot when my starter went bad lol
the hardest part of the whole swap is the pedals. a pita to climb under the dash and work with that crap. its a simple procedure, just unbolt the stuff and replace with the 5 speed pedals. you will have to take the steering column OUT of the car, it may be possible to just drop it down but i would take it out completely. to get it out of the way and make it alot easier on you. and also i woull HIGHLY RECCOMEND buying the nice clutch cable and quadrant or FWA setup now, you will eventually do it anyways and if you swap that quadrant on now it will save you headaches later. i put my aftermarket quad on after it was in the car and it was a PITA!!!!!!
the AOD speedo cable currently runs throught the hole that a clutch cable goes through in a t5 car. you will have to unhook it and run it though a different hole. not a hard deal but its a pita to fish your hands around behind the dash.
the rest is simple just like changing the clutch on a 5 speed car. except your taking the AOD out and replacing it with a 5 speed.
take the aod out, get the tranny cooler lines out and take them off the radiator.
take the aod shifter out and toss it aside. you will probably have to enlarge the hole in the floor. you will have to cut it about an inch higher towards the front of the car, to gain access to the front bolts for the t5 shifter.
under the car you will take the flexplate off, in the AOD car there wont be a pilot bearing in the crank, DO NOT FORGET TO install one. first then you do when its out in hammer in a new pilot bearing, so you dont forget. then add a flywheel and put on a new clutch. then bolt up the t5 like normal.
when i did my swap it felt strange the car felt weird like i made a frakenstein out of it but that feeling went away and the car started settling down and really feeling like a factory 5 speed car!
good luck and if you have any questions i am just a PM away and can help you!!!!
