At 108,000 miles, it could be a number of things. Have you recieved a flashing o/d light on the dash panel ?
Quick Note: Please do NOT adjust line pressure unless if you're sure you know what you're doing (most people don't). If you adjust the line pressure, and you don't know what you're doing, you will cause more problems than the ones you currently have.
As for changing the transmission fluid, the regular maintenance for the transmission should be a fluid change every 30k miles under normal conditions, or 15-20k under harsh driving conditions. You should always use at least Mercon V or superiror fluid, as that is what is meant to be used in the 4r70w transmission (the kind of transmission the 98-04 automatic GT's come equipped with).
If you're unsure whether the transmission fluid should be changed or not, then check the transmission fluid coloring on the end of the transmission fluid dip-stick. If it's not a pinkish/red color, and if it's turned darker (like brownish maroon), then it needs changed.
As for the accumulator pistons, the accumulator pistons in the 4r70w automatic transmissions is pretty stout. They are rubber bonded, and are meant to take abuse. I wouldn't bother with them until you're sure it's an internal transmission problem, and not something else like bad fluid or valve body clogging.
