I have an 87 LX 5.0 with 115K and an AOD (I know, I know...)
AOD is acting up -- I think it might be dying. It's not shifting right (delays in shifting or won't shift out of first when cold). Sometimes it rev's up and then clunks into gear -- other times it will shift/lurch when I come to a stop.
I am wondering if there is anything I can do to mitigate the problem short of just getting a new trans. I recently bought the car, so I'm not sure if the fluid has been changed recently or ever... Should I drop the pan and replace the filter & fluid? I have not done this before... any hints I should know before I start??
Does the new fluid get dumped into the dipstick hole under the hood? If not, where do you add fluid on an AOD?? I didn't see a fill spot.
I also bought some transmission fix stuff from the auto parts store... supposedly supposed to help seal up leaks and smooth out rough shifts.
Any suggestions are much appreciated!
