AOD trans tech
  • Thread starter Thread starter lxarlo
  • Start date Start date Feb 18, 2007
L
lxarlo
21
  • Feb 18, 2007
does anyone know anything about the aod? i have built one with the wide ratio 4r70w gearset, and the coupe in which its installed has a 4.10 ring and pinion. problem is that it doesnt stay in second gear long enough to take advantage of the available power. all other gears are fine. is there any valve body mod which i can do to extend the time in second gear?
L
lang williams
567
cleveland, oh
Feb 18, 2007
  • Feb 18, 2007
I have read some where there is a special valve body required to run the 4r70w gear set in an aod, it might have been on the performance auto website or lentech. i have the gear set an want to build a aod with it, how hard is it to rebuild an aod?
L
lxarlo
21
  • Feb 19, 2007
hmm i was thinking of getting a tci valve body anyway. well on the car that i tested, i know the ring and pinion messes up the governor and thats what messes up the shift points, so next car i do will be no lower than 3.55s. oh well i guess more searching for me. thats what sucks about doing auto trans, the average enthusiast doesnt know what im talking about anyway. thanks for the response. as far as rebuilding an aod, if youve done a 4r70w, then you can do an aod. just make sure you take your intermediate clutch pack clearances and endplay, as you will now have a 4 plate intermediate clutch pack, and the 4r70 reverse/od drum. use the 4r70 od band too. i got an aod jumbo od servo from tci to complete the swap.
Nopantz
234
NJ/US Merchant Marine Academy
Feb 19, 2007
  • Feb 19, 2007
go to clickclickracing.com for AOD tech. They are a huge help.
M
Mateo90-351-EFI
San Antonio, TX
Feb 19, 2007
  • Feb 19, 2007
L
lxarlo
21
  • Feb 19, 2007
the link doesnt work. i should say the site.
Nopantz
234
Feb 19, 2007
  • Feb 19, 2007
http://www.clickclickracing.com/
L
lxarlo
21
  • Feb 20, 2007
thank you soo much!!! ive hit pay dirt!!!!!
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
J
Dies on cold start unless throttle is applied and bogs on initial acceleration
  • jake13
  • Jun 26, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2024
Mindseye007
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
