aod
Will it not shift into OD or when it shifts there is no OD, it kinda goes into neutral? If it is the latter it sounds like the OD band is burned up. If it is the former then you might want to check TV cable adjustment and you might have some issues with piston seals in the valve body.
Do a search on the screenname "macx". He has put up some good links to things to look for and how to fix them in no shift situations.
it just simply wont shift to od itd like 1st shift ok 2 shift ok 3 shift ok thats it as soon as it hits around 55mph no shift selection it just holds 3rd hey thanks by the way ill look that up let ya know what happens cool
