AOD
  • Thread starter Thread starter mhjo
  • Start date Start date Oct 18, 2010
mhjo
490
Oslo, Norway
Oct 18, 2010
  • Oct 18, 2010
Just got the car back from the garage after AOD swap. Everything works fine except that it takes 1. gear too long to shift to 2, so I promised mechanic to post you guys to get some ideas.
1. gear - doesn't shift before you really push accellerator
2. gear . switches to quickly into 3.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 18, 2010
  • Oct 18, 2010
Make sure the TV adjustment was done properly and that the TV linkage was hooked up properly.
mhjo
490
Oslo, Norway
Oct 19, 2010
  • Oct 19, 2010
Any more details?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 19, 2010
  • Oct 19, 2010
How about some more info from you ? Was the AOD new/rebuilt ? What kind of torque converter are you using ? What TV linkage did you use ? What is the current TV vaccum reading at ? Does it have a shift kit in it ?
mhjo
490
Oslo, Norway
Oct 25, 2010
  • Oct 25, 2010
I have to check this with my mechanic.
Hoever, after some miles of drivind, the 1. gear now behaves normally.
Only problem left is 2. that switces too quicly into 3. and missing kickdown from 3. to 2.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 25, 2010
  • Oct 25, 2010
With AOD transmissions it is absolutely critical that the TV be adjusted properly. If it is not you can completely burn the trans out in less then 50 miles.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
