  • 1994 - 1995 Specific Tech
AODE help
  • Thread starter Thread starter abusedstang
  • Start date Start date Apr 10, 2005
1 of 2 Next Last
abusedstang
103
East Hampton, CT
Apr 10, 2005
  • Apr 10, 2005
I recently inhereted a 94 Mustang Gt covert with 139k on an entirely original package. NOTHING has been replaced on it. Other than the back window leaking, the car is immaculate with one major exception...The notorious AODE automatic. Here's the problem: going down the highway after about 45 min, the car will drop out of overdrive back into 3rd gear and then go back into OD after a few seconds. It also will pop out of any gear at random for about 2 seconds and slam back in. its been doing this for about 30k. Ironically its been doing it less with more mileage. What kind've problem am i looking at? Anybody have this happen to them? Any help would be great. I really want to restore it with about a 10k budget. it still shines like new and has the 302. :damnit:
KingDiamond
637
Chicago, IL
Apr 10, 2005
  • Apr 10, 2005
Might be the MLPS sensor.
J
jasonlee0704
219
Kansas City, MO
Apr 11, 2005
  • Apr 11, 2005
I had a similar problem one time with my AODE, it would randomly upshift/downshift at weird times. I took it to Reynolds Ford here, and they said the speed sensor on the input shaft was intermittently fritzing out. They replaced it, and everything's been fine since then with the tranny.
abusedstang
103
East Hampton, CT
Apr 11, 2005
  • Apr 11, 2005
I hope its something simple. I might just take to the dealer and do a diagnostic. It was driven for years by my over-the-hill father so theres no real abuse. How much mileage can a stock aode take?
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Apr 11, 2005
  • Apr 11, 2005
WELCOME TO STANGNET!!!
DO us a favor and repost here when you find out what the dealer tells you.
This is a common problem with these cars, and as many times as Ive seen this posted, I dont think there has ever been give a DEFINITE answer as to the exact cause of it.
RC
bjl95mustang
1,495
Austin,TX
Apr 11, 2005
  • Apr 11, 2005
when was the fluid changed? does it do it when you first start driving it when it's cold? have you checked the fluid level?
abusedstang
103
East Hampton, CT
Apr 12, 2005
  • Apr 12, 2005
The trans war serviced at 84k, about 60k miles ago and roughly 4 years ago according to the paint pen markings on the plastic panel covering the radiator!!! The retards that serviced it before just felt the need to write the info in paint all over my car! This trans shop is a work of art. Evertime I've heard a story about them... it's been how the transmission on thier car quit months after being serviced. I seriously thing they are doing this on purpose as opposed to simple incompetence. Cost aside, I think the dealer is still my best bet. It goes in next week.
95Vert
1,785
North Mexico (deep south Texas)
Apr 12, 2005
  • Apr 12, 2005
Ok, I had the same problem, but when I took it to get the shift kit installed, it came back all better. Also, it had been doing it whenever I turned to the right. My tranny cooler was leaking fluid, so I filled it back up and the problem it gone. I don't know if I helped, but that was my experience.
mustangsammym
44
Georgetown Texas
Apr 12, 2005
  • Apr 12, 2005
aode problem
Ok so what you are saying is that when you are driving no matter what speed, the transmission switches from overdrive into a lower gear at any given moment.
This happened to me and i could not figure it out for over a year. I tried everything. I replaced tps, maf, ait sensor, tranny service. But to no avail.
I had TWO tranny shops tell me they were out of ideas.
So I took matters into my own hands and came up with my own answer.
The transmission range sensor was at fault. It is located where the linkage hooks up to the transmission. It has two bolts that bolt to the tranny and has a hole where the gear selector shaft goes in.
It is available at the ford dealership for about $120.
There is my two cents
SilverFoxbody
149
#10
  • Apr 12, 2005
  • #10
That should fix your problem.....
mustangsammym
44
Georgetown Texas
Apr 12, 2005
#11
  • Apr 12, 2005
  • #11
tranny range sensor
the tranny range sensor is also known as the PRNDL Switch
D
DJiCE
117
Bloomfield, NJ
May 4, 2005
#12
  • May 4, 2005
  • #12
Mine has been doing that for years also, happens more freuquent in highway.
where I would slow down, and it would downshift and then when it would upshift my engine would rev up and tranny hestitate ..
Tranny works fine when I punch the gas and it cycles thru all the gears in order.
anyone able to pinpoint this problem or it could be anyone of those sensors ?
davins130
424
#13
  • May 4, 2005
  • #13
be like me and dont try to figure it out, buy a different one
droptopford 5 0
427
May 4, 2005
#14
  • May 4, 2005
  • #14
i had the same exact problem when i bought my car... when i test drove it i never got to that point where it was warmed up enough to do it until it was in the driveway... ill look up what i had done, and since then its been cherry i know i opted for a new converter while i was in there and the upgraded 1-2 accumulator, but i cant remember what was wrong, ill look at the description of what i had done on the reciept tomorrow if im not bogged down with work... BTW, what is the name of that crappy tranny shop? im close to you and dont want to get a bum deal next time i have work done...(converter and shift kit, or t-5 swap... )
BDAWK2002
139
Old Bridge N.J.
May 5, 2005
#15
  • May 5, 2005
  • #15
AODE to T-5 swap......That will fix it!
D
DJiCE
117
Bloomfield, NJ
May 6, 2005
#16
  • May 6, 2005
  • #16
that's my plan, I just waiting for the tranny to die on me...
Funny part I bought the car well over 8 years (94 GT) and dislike that fact it was a AUTO, but the dealership gave me a great deal on it ...
and said to myself that once this tranny goes it's going in for a T5 swap.
Still Waiting for it to go ...
BDAWK2002
139
Old Bridge N.J.
May 7, 2005
#17
  • May 7, 2005
  • #17
That's my plan too.My AODE has been leaking for 3 months now and there is no way in the world that I'm gonna fix it or put more fluid in.I just wish the damm thing would blow up already so I'm forced to make the swap!!!Either that or the car is gonna catch fire from the fluid hitting the exhaust pipes.
droptopford 5 0
427
May 7, 2005
#18
  • May 7, 2005
  • #18
same here, but mine died on me before i decided this and dumped a grand into it before making the decision... now i might as well just go through with it, but i hear ya on the tranny fluid on the mid pipe...i thought something important was wrong for the longest time when it was -20* out and i wasnt putting the car on jacks...
livenfine
601
#19
  • Jun 9, 2005
  • #19
Still waiting...any word on the fix???
BDAWK2002
139
Old Bridge N.J.
Jun 9, 2005
#20
  • Jun 9, 2005
  • #20
I fixed mine......Just orfered a tremec and swapp kit today
1 of 2 Next Last
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
More Issues With New Edge
  • Blackout67
  • May 3, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2025
Blackout67
R
Engine Fox body doesn’t run hot until I start driving
  • Rose5oh
  • Mar 17, 2025
Fox 5.0 Mustang Tech Jun 7, 2025
limp
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
