This is weird. I have a 95 GT. When I gun it and the car is cold, it runs like a champ (tires sqeal). After the car heats-up (i.e. drive at high speeds for 10 or more minutes) and I stop and then gun it, my car DOESN'T MOVE AT ALL (it slips like it is in neutral). If I gradually press the gas it does't slip at all. When I am at high speed and I gun it (down shift), it just slips until I let off the gas and gradually press the accelerator (it catches). So what do I do, I swap out transmissions and install a edge stall converter. When I pulled the old transmission, I notice that IT was used (it had "core" on it). After replacing the tranny, my car still does the same thing. I went ahead and installed a JET Chip. No change to the slipping. Is this a PCM problem? Something electronic going on here? Is it the rear end/clutch packs? Need some thoughts here.
