  • 1994 - 1995 Specific Tech
aode to t-5 swap ?
  • Thread starter Thread starter 94GTMOOSE
  • Start date Start date May 1, 2008
94GTMOOSE
303
jersey shore
May 1, 2008
  • May 1, 2008
i am not sure if i need to change the trans cross member. If i do need to change it. is there only a stock replacement, or is there an adjustable one like the FORD Racing one.
also will this kit fit? JEGS/Ford Racing/Red Line 5.0L Complete Clutch Replacement Kits Seems like a great kit for people like me that are going to swap to a t-5 like. Addresses a lot of needs all in one kit.
bonestock94
61
NY
May 1, 2008
  • May 1, 2008
I didn't need to change the crossmember when I did the swap.
Secondly, that kit is overpriced a bit. Just get a used clutch fork, used or new flywheel of your choice, and everything else separately from summit or wherever and you should come out spending significantly less.
94GTMOOSE
303
jersey shore
May 1, 2008
  • May 1, 2008
i do get what your saying about the used parts and that it might be cheaper. But after paying individual shipping charges and the time it would take to get all of them, i am thinking its worth it for me. .
i do need to know if it fits our cars though.
mustang6tee8
375
College Station, TX
May 1, 2008
  • May 1, 2008
I think that kit is a pretty good deal! Like you said moose, everything that you need is there. If I were doing an extensive swap like this, I'd want to start off with all brand new parts.
Do you already have the shifter bezel for a manual?
Also, consider replacing the rear main seal and the U-joints on the driveshaft while it's out (if you haven't recently). They're cheap, and the peace of mind is priceless!
94GTCoupe
1,412
92
79
CA
May 1, 2008
  • May 1, 2008
mustang6tee8 is right,it's a good deal.dont forget you need the upper and lower shifter boot's.your also going to need to open the shifter hole on the trans tunnel a little.i used the lower shifter boot as a guide.
ProKiller
3,064
15
78
PA
May 2, 2008
  • May 2, 2008
agree with everybody else. you can reuse the cross member. the kit doesn't seem like a bad deal.
94GTMOOSE
303
jersey shore
May 2, 2008
  • May 2, 2008
OK i get that it is a great deal. and if i can get some confirmation that it will fit our cars i will go ahead and order it right away.
so what do you think. will the kit work on our cars or is it for fox bodied mustangs?
saleener94
153
Compton,CA
May 3, 2008
  • May 3, 2008
I got my kit from 50resto.com, itz ford racing replacement parts includes rear main seal. Only thing you should get used is a bellousing, clutch pedals(mpsautosalvage) and computer. clutch cable, quadrant and firewall adjuster is pretty good from maximummotorsport.
94GTMOOSE
303
jersey shore
May 3, 2008
  • May 3, 2008
sooooo. will it fit?
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
