Just swapped from an AODE to a Tremec 3550 (not completely done) and just tried to see if the starter would turn over w/ no luck. I removed my factory pedal assembly and swapped it with a friend who was manual but going to a C-4. The quadrant is pushing in hte pin (sensor telling the comp the clutch is depressed) and still wont try to turn over.
I haven't done an AODE swap to manual before so not sure what I am to expect.
When doing this swap is there anything I need to do to get my starter to work?
Also any other info will be greatly apppreciated no matteer how trivial. Thanks in advance guys.
