Aode Trans In A Fox Body?
  • Thread starter Thread starter Reynaldo rivera
  • Start date Start date Feb 14, 2014
Reynaldo rivera
29
puerto rico
Feb 14, 2014
  • Feb 14, 2014
what i need to run a '97 AODE transmission in my '88 fox body pony?
rbohm
6,698
550
204
tucson,az
Feb 14, 2014
  • Feb 14, 2014
everything that is used to put an AOD into a fox body, plus a trans controller.
Reactions: Reynaldo rivera
Reynaldo rivera
29
puerto rico
Feb 14, 2014
  • Feb 14, 2014
i need to use the AODE driveshaft too?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 14, 2014
  • Feb 14, 2014
Couple of things.
AODE was only used in mustangs in 94/95. in 96 the 4r70w replaced it. Regardless, that's an electronic trans and your fox body is set up for an AOD- you will need a stand alone control unit.
http://www.becontrols.com/ourfaqs/aodefaq_1.htm#08011636
What parts do I need to install an AODE or 4R70W into a fox body (1979-1993) mustang?
You will need the following items:
  • AODE or 4R70W transmission with the proper bolt pattern for your engine.
  • Baumanator TCS
  • Dipstick tube and dipstick from a '94-'95 AODE equipped Mustang (may not clear all headers)
  • Backset transmission crossmember
  • flexplate from AOD equipped fox body Mustang (imbalance weight must match engine 1968-1980 302 = 28 oz. 1981-2001 = 50 oz.)
  • shifter cable from 1994-95 Mustang
  • transmission inspection plate and transmission to engine block separator plate from an AOD equipped fox body Mustang
  • If the AODE or 4R70W transmission you sourced is from a Mustang it will have the correct shift lever if not, you will need a shift lever from a '94-'04 Mustang application.
Obviously, if you are converting from an AOD you will have most of these components. The other components are listed here in case you are wisely changing from a manual trans to an automatic
Reynaldo rivera
29
puerto rico
Feb 14, 2014
  • Feb 14, 2014
mikestang63 said:
Couple of things.
  • Baumanator TCS
the transmission its from a 97 3.8L mustang
CarMichael Angelo
8,909
234
Birmingham, al
Feb 15, 2014
  • Feb 15, 2014
Ahem. All the above stuff is incorrect (as long as you don't mind shifting it manually)
Actually, most of the stuff above is correct except the trans controller junk. I personally bought this for my 4R70W:
http://www.summitracing.com/parts/trg-aode-3/overview/
Different block plate?PFFFT!!
Can you weld? Cut the starter ring, out of your current block plate and move it to accommodate the 164 tooth flex plate.
Use a flexible trans dipstick like a Lokar, and for get about header /exhaust interference.
The reprogram kit requires you to open the trans, and modify the VB, as well as drill the case for an old school vacuum modulator. You will have to always shift the thing after that, and you'll have to wire a pushbutton w/ a microswitch to simultaneously put it in OD, while locking up the converter, but other than those two obstacles, 200.00 is waaaaayyy better than 600.00.
Personally, I would rather shift my auto trans manually anyway, gives my right hand something to do other than flip off people that p iss me off.
Reactions: f8tlfiveo and Reynaldo rivera
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Fox Prepping a '91 to start after 5 years sitting?
  • 331strokerGT
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2026
limp
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
