MikeC Founding Member Aug 1, 2002 240 0 16 SLC, UT Nov 17, 2006 #1 Nov 17, 2006 #1 Anyone know if the rear axles shafts from a 1994 to 1998 Mustang are the same as the 1999 to 2004? Seems like I heard the length is different. Not including IRS Cobras.
BennyBlown2v New Member Dec 9, 2004 1,233 1 0 Carmel, INdiana Nov 17, 2006 #2 Nov 17, 2006 #2 Length is different, 94-98 are narrower. I have a set of 99+ axles if you like...
MikeC Founding Member Aug 1, 2002 240 0 16 SLC, UT Nov 18, 2006 #3 Nov 18, 2006 #3 What about the housing? Is it the same or longer also?
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,251 17,937 224 Massachusetts Nov 18, 2006 #4 Nov 18, 2006 #4 99-04 housing is about 1.5" wider. As a result, Ford had to lenghen the 99-04 axles 0.75" each side to match. Brake hardware is exactly the same, just a wider housing and longer axles on the 99-04 cars. 86-98 8.8 housings are the same width
